350 CHEVY TIMING - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2002, 06:24 PM
Question 350 CHEVY TIMING
I am trying to find out basic timing on 350 chevy.
I have no marks to go by.The original motor was a 400 so my sticker on the front does me no good.
Stock 4-bolt with Performer Intake. Any help will be greatly appreciated.Casting numbers on block are for 69-80.ANY helpfull tips ?
Old 08-24-2002, 07:59 PM
Post
I have a 69 Corvette 350, and for that motor with an automatic transmission the book says it is 4 degrees before top dead center. This will give you a starting point but this can vary depending on the type of transmission you have, accuracy of the vibration damper, and the amount of slackness in the timing chain.
Old 08-24-2002, 09:34 PM
Post
Thanks for the tip.I will see if that will help.
Just a TH350 tranny.
Old 08-25-2002, 08:03 AM
dmorris1200's Avatar
doesn't play well with others
Post
According to my camaro manual the early 350's called for about 4BTC base timing. In 1971-72 it went to 6BTC or 8BTC for the high hp engine. In 1973 it went to 8BTC and to 12BTC for the high hp 350. But the majority of 350's from 1971 and up called for 6-8BTC base timing. Now that's what factory calls for. Every engine I've run has almost always been more advanced than called for. Especially with performance upgrades. I'm currently running my engine at about 14-16BTC and she performs just fine.
[ August 25, 2002: Message edited by: dmorris1200 ]</p>
