350 chevy wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2011, 05:29 PM
350 chevy wiring
need diagrams for charging system and starting wiring for Chevy 350 engine
Old 12-28-2011, 08:09 AM
350 wiring
Get a "How to wire your Hotrod" book....
Old 12-28-2011, 10:22 AM
The basic power wiring is very simple
- 1/0 line from Battery positive to the large lug on the starter.
- 1/0 line from battery negative to the alternator bracket (or other engine ground)
- Use the large lug on the start to connect power to the rest of the vehicle. Stock setup usually has a fusible link on the wire, but you could also use a large capacity fuse.
- There are two ways to connect the alternator charge wire.
1. Run the alternator charge wire down from the BATT post on the alternator to the large lug on the starter and put a fusible link on the starter end.
2. Run the charge wire directly over from the battery positive to the alternator.
If its a 10si or 12si alternator you also need to wire the two wire plug.
- Terminal 1 (or R) is connected to switched power from the ignition. However, there should be a small dash light bulb connected between the wire and the ignition, or you should have a 35-350 ohm resistor in the circuit.
- Terminal 2 (or F) can be connected to the BATT charge post with a short jumper. There are two wire connectors at the parts store that have this jumper built in.
Bruce
70 chevy c10 wiring(help) 2burnouts Electrical 4 11-10-2010 05:35 PM
wiring diagram for 75 chevy C10 PU DOUBLEDICK Electrical 11 05-28-2007 02:45 AM
Wiring for '48 Chevy FrankieG Hotrodding Basics 6 12-23-2005 06:29 AM
1951 chevy car wiring? alf51chevy Electrical 5 04-29-2005 08:44 PM
wiring 72 column into 51 chevy gloreb Electrical 2 06-01-2004 12:05 AM
