-   -   350 Chevy won't start (http://www.hotrodders.com/forum/350-chevy-wont-start-131530.html)
Stretch3663 01-13-2008 09:55 AM
My GF has an 05' Chevy 4x4. She says it lost all power while driving and now the engine will turn over but fails to start. All the fuses have checked out good and a fresh battery has been installed, but the engine still wont start. Any ideas or suggestions to remedy this are greatly appreciated.
79C10 01-13-2008 10:02 AM
I'd take a good look at the ECM inside the distributor . I've had 'em go out on me before , and it's exactly as you describe. One minute good. Next thing you know - nothin' .
They are cheap and easy to replace.
Make sure to use the dielectric grease that comes with it when you replace it !
Best of luck- :thumbup:
classicautoresto 01-13-2008 10:09 AM
Fuel pump, pump relay, control module, cam sensor, crank sensor, etc, etc, etc. Check the fuel pump first. Turn the key on and listen for the pump to engage. I am assuming you have verified there is gas in the tank. If you can't hear it when turning the key on, switch the fuel pump relay with another matching relay...then try listening for pump again. If still no pump engagement, pump is probably bad. If pump is now engaging, the relay is bad. If it is still not engaging, there are too many computer controlled possibilities to guess without doing a computer scan. Check the parts stores in your area and see if they have a loaner scan tool. Most just charge a deposit which you get back when done with it. Good luck, Jerry
classicautoresto 01-13-2008 10:10 AM
2005 doesn't have a distributor.
Stretch3663 01-13-2008 10:12 AM
Problem Solved
The GF was towing a trailer and the weight of the trailer was sufficient enough to allow air to enter the fuel line and starve the engine. I towed the same trailer with her truck before and didn't experience any problems, only this time she allowed the low fuel warning light to come on and thought she could make it to town. Thanks to everyone who may have read my post and not yet replied.
This "Hotrodders Bulletin Board" website is the "Best". Thanks again to everyone.
79C10 01-13-2008 10:14 AM
Guess I oughta look at the year first.
whoopers.
classicautoresto 01-13-2008 10:16 AM
It happens! :D
79C10 01-13-2008 10:28 AM
It happens! :D
To me?
all the time...... :(
Wouldn't a 2005 still be under WARRANTY???????
AntnyL 01-13-2008 12:16 PM
To me?
The warrantee doesn't cover adding fuel to the tank...! :D
Job~Rated 01-14-2008 01:00 AM
If I ever get any problems with my Dodge, I always use this - it never fails! :thumbup:
http://i23.photobucket.com/albums/b3...tyaBastard.jpg
GunnerTHB 01-14-2008 06:55 PM
That must not be stock motor either cause there was no 350 in Chevrolet pickups after 1999
somewt 01-14-2008 09:29 PM
you have to ask your self a couple of questions. first are you getting fuel, is your pump working, second do you have spark to the plug? the best way to find out is to spray starting fluid in the throtlle body, if it starts yo have a fuel problem. if it doesnt start you have a spark problem
FrostbiteRodders 09-15-2013 10:00 PM
http://www.hotrodders.com/forum/350-...ml#post1764338 if ya had any time maybe ya could pick at this thanks tons!
