350 Chevy won't start - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2008, 09:55 AM
My GF has an 05' Chevy 4x4. She says it lost all power while driving and now the engine will turn over but fails to start. All the fuses have checked out good and a fresh battery has been installed, but the engine still wont start. Any ideas or suggestions to remedy this are greatly appreciated.
Old 01-13-2008, 10:02 AM
79C10's Avatar
Viva la Migra!!
I'd take a good look at the ECM inside the distributor . I've had 'em go out on me before , and it's exactly as you describe. One minute good. Next thing you know - nothin' .
They are cheap and easy to replace.
Make sure to use the dielectric grease that comes with it when you replace it !
Best of luck-
Old 01-13-2008, 10:09 AM
classicautoresto's Avatar
Rust Buster
Last journal entry: birthday surprise
Fuel pump, pump relay, control module, cam sensor, crank sensor, etc, etc, etc. Check the fuel pump first. Turn the key on and listen for the pump to engage. I am assuming you have verified there is gas in the tank. If you can't hear it when turning the key on, switch the fuel pump relay with another matching relay...then try listening for pump again. If still no pump engagement, pump is probably bad. If pump is now engaging, the relay is bad. If it is still not engaging, there are too many computer controlled possibilities to guess without doing a computer scan. Check the parts stores in your area and see if they have a loaner scan tool. Most just charge a deposit which you get back when done with it. Good luck, Jerry
Old 01-13-2008, 10:10 AM
Rust Buster
Best of luck-
2005 doesn't have a distributor.
Old 01-13-2008, 10:12 AM
Problem Solved
The GF was towing a trailer and the weight of the trailer was sufficient enough to allow air to enter the fuel line and starve the engine. I towed the same trailer with her truck before and didn't experience any problems, only this time she allowed the low fuel warning light to come on and thought she could make it to town. Thanks to everyone who may have read my post and not yet replied.
This "Hotrodders Bulletin Board" website is the "Best". Thanks again to everyone.
Old 01-13-2008, 10:14 AM
79C10's Avatar
Viva la Migra!!
Guess I oughta look at the year first.
whoopers.
Old 01-13-2008, 10:16 AM
Rust Buster
It happens!
Old 01-13-2008, 10:28 AM
79C10's Avatar
Viva la Migra!!
It happens!
To me?
all the time......
Wouldn't a 2005 still be under WARRANTY???????
Old 01-13-2008, 12:16 PM
AntnyL's Avatar
To me?
all the time......
The warrantee doesn't cover adding fuel to the tank...!
Old 01-14-2008, 01:00 AM
Job~Rated's Avatar
Artful Dodger
Last journal entry: From behind
If I ever get any problems with my Dodge, I always use this - it never fails!
Old 01-14-2008, 06:55 PM
That must not be stock motor either cause there was no 350 in Chevrolet pickups after 1999
Old 01-14-2008, 09:29 PM
you have to ask your self a couple of questions. first are you getting fuel, is your pump working, second do you have spark to the plug? the best way to find out is to spray starting fluid in the throtlle body, if it starts yo have a fuel problem. if it doesnt start you have a spark problem
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
chevy 350 won't start Troy Smedley Engine 2 03-23-2007 05:21 AM
Will my Buick 350 (1970) fit into my 1984 Chevy K10? GFORCECONSTRUCTION Engine 0 05-22-2006 07:58 PM
chevy 350 hesitation BICHN69 Engine 2 06-25-2004 10:56 PM
