Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 Chevy won't start
Old 01-13-2008, 10:09 AM
classicautoresto's Avatar
classicautoresto classicautoresto is offline
Rust Buster
Last journal entry: birthday surprise
Fuel pump, pump relay, control module, cam sensor, crank sensor, etc, etc, etc. Check the fuel pump first. Turn the key on and listen for the pump to engage. I am assuming you have verified there is gas in the tank. If you can't hear it when turning the key on, switch the fuel pump relay with another matching relay...then try listening for pump again. If still no pump engagement, pump is probably bad. If pump is now engaging, the relay is bad. If it is still not engaging, there are too many computer controlled possibilities to guess without doing a computer scan. Check the parts stores in your area and see if they have a loaner scan tool. Most just charge a deposit which you get back when done with it. Good luck, Jerry
