350 chevy wont stay running - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2011, 09:41 PM
i have a 5.7 it starts but dies about 5 seconds later i have changed fuel pump and cam shaft sensor it has 60 psi at the furl rail it has 60 psi oil pressure and ideas what it could be
Old 12-06-2011, 08:05 PM
The mobile view is crap
a little info about the vehicle would be nice! During this five seconds does it run good or like crap? What vehicle is it? If it runs good for the five seconds i would say that is sounds like the anti theft system if it is new enough for that
Old 12-06-2011, 08:16 PM
Cape Cod Bob's Avatar
Don't just start throwing new parts at it hoping you will fix it. Try to do some trouble shooting.
If you got a lot a sensors you need to satisfy them.
Of course , gas, spark, compression.
You got that just losing one of them.
Old 12-06-2011, 09:27 PM
Yes it runs great just shuts off it is a 98 4x4 it dont have the theft system that i know of it does not have a securityy light it did have keyless entry thou the key pad got lost
Old 12-07-2011, 06:41 AM
Did u have this truck running before? Is this a new to u truck. Did it have a chip in the key. Cause thats what it sounds like. You using a key with no chip and won't stay running with out.
Old 12-07-2011, 08:21 AM
455olds's Avatar
I have a '88 GMC with a 350. My problem was the pickup coil in the distributor, I don't know if yours has one though. It plugs into the module in the distributor. You can test it by unplugging the leads and using a meter set to ohms you test between each connector and it should read 500-1500 ohms. Then test between each connector and the distributor body, it should read infinite. If it fails it is bad. Be sure to test when it is not able to run. Also when in no run condition check for spark, I used a timing light to find the lack of spark. It also may be the module in the distributor, if you replace it use the recommended grease or the new one will fail quickly. I hope this helps you. Oh, it also may be a coil heating up and failing and try Chevy Talk forum also.
Old 12-07-2011, 05:50 PM
T-bucket23's Avatar
Wiki Edits: 26
Does it start right back up or do you have to wait a while.
If you have to wait, check for spark and injector pulse when it is not starting. Sounds like a security system issue. Almost everything in that year had passkey.
More info on the vehicle will make it easier to help.
what body style, engine etc.
Chet
Old 12-07-2011, 09:34 PM
Yess it starts right back up and i sold it and the guy gave it back cause it did this one. Day when he tryed to go to work but he did have new keys made it did nothave a chip in it
Old 12-07-2011, 09:35 PM
It is a 5.7 vortec new body style extented cab long bed 4x4
Old 12-08-2011, 07:33 AM
Are you using the original key, or a Wal-Mart copy cat?
454 TBI wont stay running. Stuk4x4 Engine 2 06-22-2010 03:45 AM
chevy 383 stroker starts but wont stay running the specks for the most part are here pealjoints Engine 3 08-06-2009 05:26 PM
95 LTl wont stay running chevy_boy704 Hotrodding Basics 6 03-21-2007 07:43 AM
why wont it stay running 67bird Engine 10 02-12-2004 11:35 PM
Car Starts but wont stay running ProphecyXI Electrical 7 05-19-2003 04:24 PM
