350 CI Rebuilt Setting for many years
I have a rebuilt 350 that has been setting for many years and I am ready to install in my project truck. The question I have is how should I check the 350 out to make sure I have a running 350?
Thank you for your help. |
Depends on how it was layed up and taken care of, climate controlled? Sealed openings, etc? I'd be concerned with lack of cam break-in lubrication, rusted cylinder walls, valve springs that have taken a set if left compressed. Does it rotate freely? I wouldn't try that without putting some oil in each cylinder, and not rotate it by the crank bolt. Was the carb left out in the elements? Is the distributor clean and rust free?
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
• First start up |
rebuilt 350
Are you wanting to know if its frozen up, ring stuck from setting so lond, I start by putting it on and engine stand with oil in it, prime with a distur. tool to build oil pressure, after it starts in most of the rockers turn the engine until oil come from all of them, then do a compression test on.
| 350 rebuilt then sat for 2 years. not fired | candrive55 | Engine | 5 | 12-20-2009 09:18 AM |
| TH 350 just rebuilt | Supernova72 | Transmission - Rearend | 7 | 02-02-2004 08:36 PM |
| 350 years | 70 nova | Engine | 4 | 03-29-2003 05:33 PM |
| 350 years | 70 nova | Engine | 5 | 02-23-2003 11:53 PM |
| setting up my 350 | ashley | Engine | 1 | 01-16-2003 07:46 PM |
