Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 Crank Shaft Question
Old 08-30-2012, 09:33 PM
S10 Racer's Avatar
S10 Racer S10 Racer is offline
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
A thread chaser is a tool used to straighten up threads instead of cutting new ones like a tap will. You use it the same way as a tap. Use anti seize on the chaser when using it to make it easier to do it's job. You should be able to get one online or at a good auto supply store. I believe you will need a 7/16"-20 thread chaser which is the same size & pitch as the bolt.
