350 crate engine overheating - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2009, 03:04 PM
i just recently installed a new sbc 350 engine in my 85 Monte Carlo SS, after installation the car started to overheat while driving >220 degress and getting to 260 degress. Everything is new on the engine except the water pump which came of a serpentine set up i got from the salvage yard.
Old 01-23-2009, 05:07 PM
I've got an '86 SS with a 350. Just thought I'd suggest you may have the wrong water pump. I believe the serpentine set-ups had a reverse flow pump compared to the old days(1960's). I'm not certain. You might check with NAPA or a dealer.
When I first installed my 350 it got hot. Found out the upper rad hose was missing what looks like a plastic elbow that keeps it from getting pinched by closing the hood. That seemed to fix it, but I bought a 3row radiator for peace of mind. Not saying you should. Just a thought. Good luck!
ssmonty
Old 01-23-2009, 05:24 PM
ssmonty
That's where I would start also, along with verifying proper timing. On a side note, I had an 85 SS a while back, and have some parts yet, if any interest.
Old 01-23-2009, 05:35 PM
I was thinking the water pump also...it's a reverse flow pump from a serpentine set up but may be old and worn out! I was thinking of purchasing a high flow reverse flow water pump i saw on ebay! Radiator is brand new but i think it's only a 2 row radiator not sure!
Old 01-23-2009, 05:37 PM
what parts do you have? My brother also has a 84 SS is always looking for parts!
Old 01-24-2009, 01:43 AM
DoubleVision's Avatar
Are you using a serpentine or V belt set up? A V belt must use a standard flow water pump. (Clockwise) A serpentine can use both depending on the set up of direction. Some Serpentine systems use a smooth water pump pulley which is reverse flow (counter clockwise), a ribbed or grooved water pump pulley is standard flow(clockwise) So if your running a V belt with a reverse flow pump it`s going to run hot.
Old 01-25-2009, 07:04 PM
I would like to say that i solved my overheating problem. I did the things that you guys n gals suggested:
1. changed thermostat, the new one i had was a bad one. took the bad one and put it in some boiling water and it never did open up.
2. after changing the thermostat, it started to heat up but not as fast. so my next step was the fan clutch.
3 changed fan clutches and it didn't help, so i sat and looked at the engine real good and "Ding" the bell rung in my head.
4 Since the engine is no longer on a v belt setup and now is a serpintine setup, the fan needs to rotate the same way as the water pump.
5 changed factory fan to a reverse fan and all my overheating issues was solved.
Thanks to all who put a post on my issue!!!!!!!
Old 01-25-2009, 07:40 PM
sbc overheating
I would say you also have the wrong water pump. what temperature thermostat did you put in?New? I would also check that the cooling system is not airbound.
Old 01-25-2009, 08:31 PM
The water pump is a reverse flow water pump and the thermostat is 160 degree. The first thermostat was new but bad, so i changed it and it works correctly. I just drove it for about a hour and temp didn't get above 200 degrees. It just skipped my mind that the stock fan for a v belt drive will not work on a serpentine drive set up.
Old 01-25-2009, 08:41 PM
reverse rotation, not reverse flow
Old 01-26-2009, 12:23 PM
correct reverse rotation
66 chevelle malibu and 350 engine questions person Engine 1 09-04-2007 01:19 AM
350 overheating person Engine 14 08-27-2007 06:51 AM
1969 350 375HP GM Goodwrench Replacement Engine Big Daddy Teez Engine 2 03-21-2006 08:36 AM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
GM 350 Engine overheating wizofnet Engine 14 01-28-2003 02:09 PM
