350 crate engine zz4 in 81 buick regal - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2009, 12:03 PM
Jus broght a 350 crate engine zz4(10243880) 95-00 votec to rebuild and put in my 81 buick regal! Everything is on the engine except for the intake manifold, carb, headers & the tranny. First off is everything gonna work out right & to complete the engine wat a good intake, carb & wat tranny to put behind it
Thanks Seanj
Old 11-02-2009, 12:43 PM
Tranny will bolt right up, all of your brackets will bolt up, and assuming it already had a small block, the motor mounts will bolt right on.
Make sure you use the flexplate/flywheel that comes with the motor though, those are different.
For an intake, you'll need a vortec specific one. Check any of the big parts houses for one. Pretty basic swap there, about as straight forward as they come.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
350 crate engine overheating dirdeh20 Engine 10 01-26-2009 11:23 AM
Help with SBC 350 Crate engine ID / Specs & more 5_speed Engine 16 12-26-2008 03:58 PM
350 crate engine erimar77 Engine 3 02-04-2005 10:07 PM
prepping and starting a new 350 crate motor 65truck Engine 2 09-29-2003 12:29 PM
