Hotrodders Bulletin Board
#1
350 crate hp add ons
hey all,ok i am going to buy the 265 hp crate engine from the dealership. so how can add on some hp for some what cheap. and is a new crate a good idea or should i just get one rebuilt but i feel rebuild shops are going to ******* me. but a friend of mine said crate engines are not has high quality as we would think. he said its how fast that guy can put it together and get to the next one . so what should i do? i still like the crate idea thx for the help...
#2
re: 350 crate hp add ons
Is that the goodwrench one?
#4
blue85 those crate engines are a good place to start and are pretty reasonable. I would get a mild cam like the summit1003 or the xe256h that has .447 lift on the intake and .454 on exhaust. that will give u some good hp for cheap
#7
I would highly recommend a Jasper. Every engine is
run to check for leaks and problems. The quality is second to none. Since the engine has been run, break in is done, proper oil to all parts is there, plus with a 3 year 75K warranty nationwide you really can't go wrong. You can also order the engine with a cam up grade and SR torquer heads. Give you a good 300 HP set up. Cstraub |
#8
I second the Jasper engines suggestion. I know of several in local street rods and the owners are very pleased with them.
Vince |
#9
ok guys i would like to add some hp to the crate 350 .should i port and polish heads mabey mill them I want to cange the vavles to macth cam. i heard that the new rods in them are cool. so what part combos are out there????
#12
what kinda vehicle is this going in? What tranny and what rear gears are you running? Just Curious
#14
If it was me...I would buy a short block.From a company with a good reputation or from GM.
As mentioned the heads and cam are the keys to power.Any head you buy from the factory can be beat by an aftermarket company. Everyone is hot on the GM Vortec heads.As they should be,they are the best flowing regular factory production heads for a small block to date.They are even better than the World Products S/R Torquer heads.The real drawback is that they require a special intake manifold to use.This greatly limits your intake manifold choices. What many haven't seen is that a company called Pro Topline has bean producing Vortec heads for about two years now.They will slightly out flow the factory GM Vortec heads in stock fashion,and they are thicker around the ports and they also have thicker decks.This means they are a more durable head that is going to last longer than the thin casting GM Vortec head.They also require the dedicated Vortec intake manifold. Now wile this sounds good,they also offer a head called a Torker.It has a D shaped combustion chamber versus the heart shape.It features the same Vortec port but it accepts a regular intake manifold.Now you have a lot more options. You sound like you are going to be wanting a modest amount of power so one of these is what I would go for. You can get the Vortec head for about $600. from Mike Stark at http://www.cfmperformance.com./ They come with better valve springs than a GM Vortec and they don't require machining for cams with .500 lift.The GM Vortec requires this machining for extra cost.That puts the GM Vortec head at about 50-100 bucks more than the Pro Topline's. As for a cam I would go with a Comp Cams XE262H- 262 270 218 224 462 469 110 You can use a stock converter, a 342-3.90 gear should be used.You can use a 3.08-3.31 gear and get away with it but it won't be as good of a match with the powerband.It will also love a 2400-2600 converter,but these are things you can add if you want more performance later. Last edited by thrasher : 11-19-2003 at 10:53 PM. |
