350 csb - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2013, 12:14 PM
350 csb
I have a 350 csb I was going to convert to a 383 stroker but decided to just keep it a 350. I have a cam, pistons, rods,. can I still use these if I keep it a 350
Old 06-24-2013, 12:35 PM
vinniekq2's Avatar
what parts do you have and what are your goals
Old 06-24-2013, 01:07 PM
Pistons would be unique to a 383's 3.75 inch stroke. If the rods are 5.7 inches between pin centers they will fit to a standard 350 piston. If they are 6inch rods they require a unique 350 piston with a raised pin.
I rather think at this point that it's probably less or at least not more expensive to continue with a 383 crank.
Bogie
Old 06-24-2013, 02:38 PM
techinspector1's Avatar
Wiki Edits: 326
What fostered this decision?
CSB suffix not found Nomad35 Engine 5 07-03-2011 12:42 PM
CSB oil pan BestDamnGarageInTown Engine 1 06-10-2009 06:54 PM
Volvo 164 (350 csb) jolle55 Introduce Yourself 2 06-13-2007 05:21 PM
csb heads stout_s10 Engine 10 02-15-2007 11:12 AM
csb 350 in a pu jayty97 Engine 3 06-25-2003 09:29 PM
