350 double roller timing chain help..... - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2005, 08:55 AM
I have a 1997 Vortec 350 block and I'm in the process of replacing the original timing chain with a double roller. I removed the original crank gear O.K......but how do I hammer the new gear on without destroying the thrust bearing?.
Old 09-12-2005, 09:27 AM
New Member
take a harmonic balancer installer or something of the same design then push the gear on using a spacer(s).
Old 09-12-2005, 09:28 AM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
It should slip over the snout,and tap it on with a deadblow.Unless the Vortec crank is differnet and uses something other than a traditional crank and keyway.Work your way around the sprocket in circles until it seats. You should not have to blast it to get it on. I would wait though and see what someone else says,I have not worked on the Vortech,but I think it would be the same.
Old 09-12-2005, 10:56 PM
larryblack's Avatar
Certified Lead Foot
use some grease too. I have used a 2x4 upon occassion with a 3 lb hammer smacking the 2x4. Heavy swings not needed. Tap and move, tap and move.
Replacing the Timing Chain '64 Ford 390 Billy Boy Engine 14 12-26-2011 07:02 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Help 350 rocket bad timing chain & low oil pressure? 71oldsmann Engine 2 03-14-2005 11:45 PM
Double Roller vs Standard? Jag Daddy Engine 1 05-06-2003 10:57 PM
BBC Timing Top Rod Engine 0 06-09-2002 08:29 AM
