350 engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2013, 07:33 AM
mjc's Avatar
mjc mjc is offline
Last journal entry: REAR WINGS (FENDERS)
350 engine
hi guys just a quickie ive started to re assemble my 350 which has sat a while ,the inner block walls and casting ie inside where the torque converter live have surface rust on them which ive cleaned off my question is can you paint this to protect it thanks martin
Old 02-13-2013, 11:23 AM
BOBCRMAN@aol.com's Avatar
Yes use a quality epoxy paint. In the day we used GE Glyptal. A substance used in electric motors. Still available under different names.
Swap 250 engine and saginaw 3sp to 350 engine with t-350 or another manual? southerntidefan Transmission - Rearend 13 02-04-2011 10:17 PM
350 engine 350 Turbo TreeTop Engine 1 07-06-2010 08:04 AM
Wich heads do you recommand for OFFROADING -305 or 350 on a 350 engine? offroader9 Engine 1 04-07-2010 01:07 AM
350 Crate Engine: Loud humming sound after engine warms up sofa1515 Engine 2 01-11-2010 06:48 PM
are 350 chevs and 350 olds the same engine?L@@K flatheadfever Engine 8 02-14-2006 02:45 PM
