Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 Engine Code?
Old 01-27-2013, 03:27 PM
techinspector1's Avatar
techinspector1 techinspector1 is online now
Wiki Edits: 326
Originally Posted by Josh102chevy View Post
GM13 hecho mexico. Don't have the main casting number. Covers are back on. Umm why does it have a 8 and not a 3? And why can i find the LYC on the front of the block right beside the head. Or if you go to Naztyz28.com would it be the LY?
Josh, really, can you see how it will be difficult for any of us to help you if you don't provide all the information? Forget about the damned suffix code and post the head numbers. And to answer your question, "why does it have a 8 and not a 3"?....... It doesn't have an 8....... If you get in there with a fine-point pick and scrape around, you will remove the crud that makes you think you're seeing an 8.
I'm through here until I see some head casting numbers.
