350 engine I.D. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2011, 03:04 PM
350 engine I.D.
Ok so i picked up a engine from a dude about a month ago for 100 bucks i know its a 350 flat top pistons cast crank 4 bolt. I was told its a crate engine. On the rear it is stamped hecho en mexico
So heres what i have
Block front MA14800
rear 3970010
heads 3998993 gone now are 2.02 that i put on
side 010 so i know its a 350 block
rear clock 11am-12noon
random rear number 86
4bolt main cast crank
Aluminum Flat top pistions
cam idk wanna find out
please can anyone help an please i dont wanna hear oh its a crap engine or crappy smog heads i just wanna know what this engine is. I think its a gm mr goodwrench but i also think its a target master
Old 08-31-2011, 04:49 PM
Richiehd's Avatar
JS-70
Goodwrench crate motor.4 bolt 350. 2 piece rear main. Dipstick on either side. (or both sides) I have one I am building now. Have heard good and bad about them. Clean it up, square it up, add studs, windage tray, and clean and polish and Glyptal the block. Drive it!
Old 08-31-2011, 04:52 PM
see thats what i thought but my block only has one side dipstick.
Old 08-31-2011, 06:12 PM
Richiehd's Avatar
JS-70
Are you sure? One hole is even with the head surface the other side has a boss cast in the side. Take a better look, I ll bet im right!!
Old 08-31-2011, 06:26 PM
yeah I looked hard on both sides with the pan off to. Only one
Old 08-31-2011, 11:20 PM
DoubleVision's Avatar
It`s nothing special, but it does okay. Most of these engines didn`t come with flat top pistons. So I would bring one to top dead center and measure how far down in the bore the piston is. If it`s .045 or more then somebody has been through it before and installed "Rebuilder" pistons with a reduced compression height. These pistons kill compression and quench, they also make for a very lazy burn. With a large chamber 76cc stock head and a stock replacement head gasket that`s .041 thick, the compression ratio will be around 7.9:1. The casting number confirms it`s a 350, did you notice the 010 on the side of the block is also the last three numbers of the casting number? Also yes, the block is a target master. Not only does it say made in mexico but the M on the deck indicates GM of mexico and the numbers your engine carries are the same ones that came on TM engines.
Where the former poster said "clean polish and Glyptal the block" my advice is don`t waste your time. Using Glyptal does absolutely nothing in terms of helping oil return. The SBC has one of the best oil return systems out there and it does a good job in stock form. If you need more oil return then you simply clean out of the casting flash on the stock locations.
Old 08-31-2011, 11:38 PM
yeah i even looked again tonight even on the oil pan there is only one notch on it for one oil dip stick. Thats why im starting to think this is a targetmaster engine
Old 09-01-2011, 12:09 AM
Yeah i was kinda leaning toward the target engine. I dont know there not really flat they look like this kinda
350 Crate Engine: Loud humming sound after engine warms up sofa1515 Engine 2 01-11-2010 06:48 PM
Engine Help. Engine Turns over Hard, like siezed yet runs awsome. Merle9069 Engine 3 10-05-2008 06:38 PM
I need engine mount bracket ideas 1930 chevy with 302 boss engine. Riley Engine 3 07-25-2008 07:29 AM
say you have a THOUSAND horsepower engine..... (technical engine question inside) lowROLLERchevy Engine 14 02-24-2007 08:26 AM
the best engine parts, chain vs. gear, engine combos jollygiant_57 Engine 6 05-01-2002 09:34 AM
