350 engine missing on 2 cylinders - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2004, 09:41 PM
This summer I bought a 71 Chevelle with what is supposed to be a 350 lt1 motor. The numbers on the block and heads seem to support this. I drove it 150 miles home and drove it for several weeks. It had a clutch problem when I bought it. It was bending the frame bracket every time you pushed in the clutch. It was not a heavy pressure plate, it had some problem. Changing the bracket and clutch,pressure plate and throw out bearing fixed that problem. Then it started to miss. Just a little at first then got worse. Now it is dead on cylinders 1 and 5. I tried swapping plug wires with a known good one but it stays on 1 and 5. I next tried new plugs. Still there I had another Holly carb so I tried that since it seemed like they were rich. No difference. I then set the points (it has a mallory comp 9000 dual point dist). I wanted to get rid of that so I ordered a HEI dist. On trying to install I found that it wont clear the intake. It has a edelbrock c4b manifold. So a new manifold is in the works this winter. I set the timing and it seems to backfire in the intake sometimes with hesitation. I ran a compression check and all cylinders are between 169 and 175lbs. I can touch the headers and the 1 and 5 are just warm where as any other cylinder is hot. You can also tell the exhaust is hot out the right bank and barely warm out the left. I tried moving the plug wires in the dist one plug wire over and turning the dist to make up the difference just in case there was a bad dist cam. The plugs all spark real good. I finally timed it by ear. Turning the dist reving the motor to get the least hesitation. It pulls hard all the way to 6500rpm but still has 2 dead cylinders. The popping in the intake rarely happens now. I ordered a dial and magnetic base and my next step is to measure the cam. Thats what I think is wrong. 2 cam lobes worn off. I installed a anti power valve blowout kit in the carb and put in a new power valve to. The only other symptom is the vacuum reading. At idle it varies from 10 to 14 real fast. As the rpms come up it steadies and rises to 21 or higher. I think if the cam lobes are bad I will pull the heads and make sure they have the hardened exhaust seats for unleaded fuel. And have a valve job done. Then it will be new cam,lifters,springs,retainers,locks, and timing chain and gears. Any other thoughts would be welcomed.
Gary
Old 11-10-2004, 09:50 PM
19_Chevelle_69's Avatar
Just making my rounds...
Last journal entry: Propane stuff - 2
Sounds like the cam I just replaced in my SBC in my truck. Mine had bald lobes on #1 Exhaust, and #2 Intake.
You can easily pull the valve covers off, and see if all the rockers are moving....
Don's Chevy Shop forums
Don
GM Tech Guild - Grand Master Technician
1969 Chevelle 355/TH350/3.08
2001 HD Sportster 1200
Old 11-10-2004, 10:11 PM
mike in nz's Avatar
pull the manifold off carefully & inspect the gaskets . you will find it has a faulty gasket . if you dont wont to do this just yet you can block off the PCV valve , start the engine & remove the oil filler cap , put the palm of your hand over the hole if it sucks your hand on to valve cover the inlet manifold gasket is leaking into the crankcase . you can also carefully spray engine start (etha ) around the manifold & if the engine rpm increases you will find the manifold gasket is leaking to atmosphere . hope this helps you & saves you from changing cams etc .
Old 11-11-2004, 06:47 AM
DoubleVision's Avatar
I would think the cam is bad, I`ve never seen a intake gasket leak so bad that it missed at all RPM ranges, if the intake gaskets were leaking that bad around the base of the manifold it would using a lot of oil also. Since you know which cylinders it is, pull the valve covers and run the engine, if you see one of the rockers of that cylinder not moving very much you`ve found the problem, also inspect it for valve train damage, broken rocker arms, bent push rods, broken valve springs, pulled head studs etc.
Old 11-11-2004, 02:55 PM
mike in nz's Avatar
try intake gaskets first .its hard to imagine that you've had mechanical damage on 2 cylinders on the same bank occur at the same time (possible but unlikley)
Old 11-11-2004, 04:17 PM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
If it is the intake gaskets causing this problem,you can take a can of carb cleaner and spray the suspected ares of the intake.If it is leaking that bad to kill two cylinders than when you lightly spray the carb cleaner on the intake/head mating surfaces,with the engine running,you should notice an idle increase.
Old 11-11-2004, 10:27 PM
I did spray the intake and carb area to check for leaks. None found. I also ran the engine with the valve covers off feeling the rockers. They all seem to move the same. I spun the push rods while running to check for a bent one. I cant believe that the inake could be leaking bad enough to do this and not leak on the top also but it is possible. I also truned the engine over with a breaker bar and watched the valves they all seem to be working the same. Thats why this has me puzzled I have done every thing I can think of other than micing the cam which is the next thing when I get a day off. I did enjoy all the replies though.
gary
Old 11-12-2004, 02:24 AM
docvette's Avatar
Wiki Edits: 12
Vacuum
Doc here:
Did you say you had a rapid fluctuation on the Vacuum at Idle?
and it cleaned up with a little RPM's?
That is indicative of worn Valve guides ..
My manual say's...
"Gauge reading : Needle vibrates excessively at Idle, but steady's as engine speed increases...
Indication: Worn Valve Guides..
But with the missing and intake popping..I wouldn't put it past burned intakes,...at least on those two cylinders anyway...
Probably ran out of lead build up in there (the guides) so maybe it's a good time to do the valves...
Doc
Old 11-12-2004, 12:55 PM
burned intake
Doc,
Is there a quick way to check for a burned valve w/o pulling the heads?
Old 11-12-2004, 01:01 PM
poncho62's Avatar
Wiki Edits: 5
Re: burned intake
Originally posted by firebird_red
Doc,
Compression test....................
Old 11-12-2004, 01:20 PM
He said compression looked okay at 169-175 on all cyl.
Old 11-12-2004, 01:21 PM
poncho62's Avatar
Wiki Edits: 5
Well then, the valves should be OK then................right?
Old 11-12-2004, 03:28 PM
docvette's Avatar
Wiki Edits: 12
Compression
Doc here,
Two ways I know of...
One is kinda shade-tree, but does give you an idea..
With it running,(and If you don't have a big *** nasty Cam) Place a business card over the offending tail pipe, if it doesn't bend out full time, but slaps against the pipe..(Wap, Wap, Wap) Think Valves...
The other is wet and dry compression tests..If it goes up on those cylinders WET that's a pretty good indication something is going wrong down there...
Doc
Old 11-12-2004, 04:01 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Is it a dead miss?
With eng. running, pull the PCV and see if there is excessive crankcase pressure.
Troy
Old 11-12-2004, 10:23 PM
docvette I agree that the vacuum says bad valve guides but I cant see why it would miss with good compression. If the guides were bad enough to make the miss I would think the compression would be low for those 2 cylinders. I was also wondering if the miss could be causing the vacuum reading to pulse.
