Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 engine stalls
Old 02-27-2013, 11:47 AM
bigdog7373's Avatar
bigdog7373 bigdog7373 is offline
Of course it's fast
I have a similar setup and was having the same problem. First make sure your idle mixture is adjusted correctly. It's very easy to do.
Check your timing without vacuum advance plugged in.
Set your idle speed. What's it currently at in park and in gear?
You may need a regulator. I have a mech pump and i still use one.
The Following User Says Thank You to bigdog7373 For This Useful Post:
liljoe1996miller@aol (02-27-2013)
