350 engine stalls - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2013, 09:12 PM
350 engine stalls
my 350 engine stalls at lights stop signs and more one day i was driven and it started sputtering and cuts out it has an edelbrock 1406 carb has new sparkplug wires,rotor someone please give me some advice
Old 02-17-2013, 05:09 AM
poncho62's Avatar
Wiki Edits: 5
Could be many things....likely the carb need adjusting or has dirt in it
The Following User Says Thank You to poncho62 For This Useful Post:
liljoe1996miller@aol (02-26-2013)
Old 02-17-2013, 06:12 AM
Its probably just the carb idle adjustment, but a little more engine information would be useful. A large cam and low vacuum can make idle mixture adjustment more complicated.
If its a relatively stock engine, just follow Edelbrock's directions and get a good idle mixture (2-3 turns out from seated is usually a good starting point). Then adjust the idle speed so it runs about 700-800 rpm while in gear (if its an automatic). That should be high enough to keep it running at a stop light.
Bruce
The Following User Says Thank You to 75gmck25 For This Useful Post:
Old 02-26-2013, 08:59 PM
vinniekq2's Avatar
welcome to the forum.Maybe delete one of your threads?
The Following User Says Thank You to vinniekq2 For This Useful Post:
Old 02-26-2013, 10:07 PM
Check the carb float. It could be going bad and filling with gas and causing the motor to sputter and flood at red lights. While driving at speed it would be less noticeable.
Old 02-27-2013, 05:21 AM
how do you change idle fuel pressure to 5psi
Old 02-27-2013, 05:55 AM
They sell fuel pressure regulators at most parts stores, including the Edelbrock brand I think. Edelbrock documentation emphasizes the possibility of carburetor problems if you don't keep the pressure within recommended limits. A vacuum/fuel pressure gauge is very cheap, so you might want to check the pressure before you replace any parts.
With a stock mechanical pump you usually don't need a regulator because it will run at about 5 psi, but a regulator is used very frequently with electric pumps that put out more pressure.
Bruce
liljoe1996miller@aol (02-27-2013)
Old 02-27-2013, 10:47 AM
bigdog7373's Avatar
Of course it's fast
I have a similar setup and was having the same problem. First make sure your idle mixture is adjusted correctly. It's very easy to do.
Check your timing without vacuum advance plugged in.
Set your idle speed. What's it currently at in park and in gear?
You may need a regulator. I have a mech pump and i still use one.
The Following User Says Thank You to bigdog7373 For This Useful Post:
Old 02-27-2013, 12:00 PM
What iS your fuel presurre with the regulator?
Old 02-27-2013, 12:26 PM
bigdog7373's Avatar
Of course it's fast
5 psi. Edelbrocks are very sensitive to fuel pressure.
Old 02-27-2013, 02:55 PM
I was thinking i need a new fuel pump but the fuel bowl is filling up,so will it be wiser to try feul reglator before new fuel pump?
Old 02-27-2013, 03:29 PM
bigdog7373's Avatar
Of course it's fast
You can check the pump by installing a pressure gauge and taping it to the cowl and watching while you drive.
Since your problem happens at idle then I highly doubt there's anything wrong with the pump. Its almost 100% positive that its carb related. Either not enough fuel or too much. Do what I said to do in my fist response and let us know what happens. It should clear up the stalling as a poorly adjusted carb or timing in the cause of this problem most of the time.
Old 03-01-2013, 04:03 PM
hey guys today i hooked up my brakebooster and my brakes got very hard to press down to the floor and car tryed to stall what can be the problem
Old 03-01-2013, 05:04 PM
bigdog7373's Avatar
Of course it's fast
Wait you hooked it up or unhooked it? It tries to stall no matter is the booster is hooked up or not?
liljoe1996miller@aol (03-01-2013)
Old 03-01-2013, 06:36 PM
The booster is hooked up
350 Trans Issue, Stalls engine in Reverse mseifried Transmission - Rearend 12 04-14-2009 01:52 PM
Engine stalls.. Dschaefer Engine 4 07-15-2008 12:40 AM
Engine Stalls cornbread Engine 1 10-19-2006 09:40 AM
engine stalls say10tatoo Transmission - Rearend 2 08-14-2005 12:00 PM
chevy 350 stalls stape Engine 8 12-07-2003 12:16 PM
