350 engine stalls - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2013, 09:13 PM
350 engine stalls
today,after driving my 84 monte carlo 350 engine aroung the neighbored after 5 min it stalls at a redlight as i started pressing the brakes cranks rite back up and does it again when i press on brakes or let off of gas what can it be FUEL PUMP,FUEL FILTER, VACUUMN PROBLEM,OR CARB
IT HAS
edelbrock carb 1406
edelbrock pro series intake
factory cam im assuming
350 sb
PLEASE HELP!!!!
Old 02-27-2013, 12:18 AM
dub's Avatar
dub dub is offline
Last journal entry: Time to drive..
It dies after hard braking?
Old 02-27-2013, 06:22 AM
yes it dies after hard braking
Old 02-27-2013, 11:59 AM
bigdog7373's Avatar
Of course it's fast
Check your other thread. Lots of responses. Someone delete this double post.
The Following User Says Thank You to bigdog7373 For This Useful Post:
liljoe1996miller@aol (02-28-2013)
Old 02-28-2013, 09:25 AM
could be your brake booster, unhook vacuum from booster and plug the vacuum off, try a hard braking situation, you wont have power brakes while doing this. if it still stalls its probably a carb situation, perhaps float level or bad needle and seat.
The Following User Says Thank You to prumora1 For This Useful Post:
Old 02-28-2013, 09:49 AM
bigdog7373's Avatar
Of course it's fast
That's so dangerous. Please don't do this on a road or anywhere near people. Your power break system is designed to work with vacuum from the engine. Without the booster working the pedal effort needed to stop the car will be very high and you will need probably twice the distance or more to stop the car. All you have to do is let the car idle and press the brake and see if it changes the idle, no need to drive it.
Old 02-28-2013, 12:34 PM
hcompton's Avatar
Old & Furious
Its not vacum anyway its fuel in the float bowl is low and under hard braking it fails. Can also be casued by too much fuel pressure flooding the engine with fuel and making it sputter out. Many cars do this wil edel carbs and no regulator hooked up. This carb needs really close to its 5psi ideal pressure.
The Following User Says Thank You to hcompton For This Useful Post:
350 engine stalls liljoe1996miller@aol Hotrodding Basics 17 03-01-2013 10:18 PM
350 Trans Issue, Stalls engine in Reverse mseifried Transmission - Rearend 12 04-14-2009 02:52 PM
engine stalls say10tatoo Transmission - Rearend 2 08-14-2005 01:00 PM
Engine stalls Jessy James Engine 20 10-26-2004 03:59 PM
chevy 350 stalls stape Engine 8 12-07-2003 01:16 PM
