-   -   350 engine stumbles,surges,hesitate at take (http://www.hotrodders.com/forum/350-engine-stumbles-surges-hesitate-take-230405.html)
liljoe1996miller@aol 03-06-2013 09:21 PM
my 350 engine with edelbrock 1406 car hesitates and stumbles at take-off i can be cruising dwn street and if i punch it it will hesitate and have loss of power what can cause this problem. vacuum ports,distributor vaccum advance, manifold vacuum then cuming to a stop it will lose power and act of if it about to cut-off then when i press gas it brings back to life PLEASE HELP!!!!!!:confused:
33Willys77 03-07-2013 06:34 AM
Whats your timing at? What distributor do you have and how is it curved? Edelbrocks like to have a lot of initial timing - so get as much initial as the motor will allow. Also, read their manual - take the time and get to understand it - it will benefit you greatly.
cdminter59 03-31-2013 08:36 PM
350 engine stumbles, surges, hesitates at take off
You don't say if your 350 engine has any upgrades such as camshaft, heads, intake, etc. But here is an article to help recurve your distributor and set your timing. http://www.crankshaftcoalition.com/w...EI_distributor With most aftermarket camshafts they need more initial timing. This also means you have adjust the distributor for less mechanical timing. Your vacuum advance will probably need a kit too.
