350 engine stumbles,surges,hesitate at take
my 350 engine with edelbrock 1406 car hesitates and stumbles at take-off i can be cruising dwn street and if i punch it it will hesitate and have loss of power what can cause this problem. vacuum ports,distributor vaccum advance, manifold vacuum then cuming to a stop it will lose power and act of if it about to cut-off then when i press gas it brings back to life PLEASE HELP!!!!!!
350 engine stumbles, surges, hesitates at take off
You don't say if your 350 engine has any upgrades such as camshaft, heads, intake, etc. But here is an article to help recurve your distributor and set your timing. http://www.crankshaftcoalition.com/w...EI_distributor With most aftermarket camshafts they need more initial timing. This also means you have adjust the distributor for less mechanical timing. Your vacuum advance will probably need a kit too.
| Engine stumbles | Irontrader | Engine | 2 | 03-05-2012 05:17 PM |
| Once warmed up, engine rpms surges 1500-2000 | jaydeedias | Modern Electronic Engines | 5 | 01-18-2012 01:17 AM |
| Engine surges | deno | Engine | 6 | 09-01-2006 05:39 AM |
| sb 350 runs a little rich and surges some... | Robbie | Engine | 2 | 11-01-2004 11:51 AM |
| 454 engine surges @ idle | heinzeroth | Engine | 1 | 05-02-2004 06:26 PM |
