350 Goodwrench crate engine questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2013, 10:51 AM
I have a 350 SB casting # 10066036 engine code 2M0 01 6VP. I would like to know what the specs are on this particular engine. Can't seem to find out a decent explanation on the web. I am also in need of assistance. My starter and flywheel are clashing together. I have replaced the starter and pressure plate (due to damage of teeth). I replaced it with the exact one that came off 153 tooth did not put a shim on just as it was when I took old off. The starter is still not making the right clearance on the pressure plate. Someone please help thanks in advance.
Old 05-09-2013, 11:13 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You obviously need to shim/adjust this starter combination to stop eating parts.
Look here for decoding information
Chevy VIN, Trim Tag and Drivetrain Information & Decoding
Semper Fi
Old 05-09-2013, 11:23 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
I believe the "Help!" Section of your local parts store should have starter shims to adjust the gear lash.
1984 full size blazer with 350 chevy crate engine questions 84blazer Engine 5 01-08-2013 03:49 PM
GM Goodwrench Crate motor crowbie Engine 7 08-13-2011 09:52 PM
10066036...350...2 or 4...Target Master/Goodwrench crate motor oldsmo Engine 8 05-16-2011 07:34 PM
Goodwrench Crate 350 pros/cons redsdad Engine 5 11-12-2004 12:48 AM
Goodwrench crate engine hutch4 Engine 5 08-08-2002 07:27 PM
