#1
350 head gasket replacement...somethin went wrong
Hey guys, im new to this forum and lookin for some help. i replaced the head gaskets on my 1999 gmc 2500 w/ 350. My first time doing it alone. i read alot of good insite in these forums and others on the valve adjusting. I thought i did good. when i finished and turned the motor over i got horrible results. it turned over a couple times and i heard a "noise". being stupid and not seeing anything i turned it again and it wouldn't turn over at all. I removed all the spark plugs and fuel poured out of #6 cylinder.(lots of fuel) anybody know why that happened and any suggestions on what to do??
Thank you for reading this Rookie wrench turner, Nate Register now (free) or login to remove ads Last edited by nate042 : 03-29-2009 at 07:16 AM. Reason: wasnt finished |
#2
It sounds to me that for some reason the #6 cylinder filled up with fuel on its compression stroke. This would explain why the engine didn't turn over anymore. What kind of fuel injection are you running? TBI? It sounds like you may have screwed the pooch on your valve adjustment.
#6
Don't get so upset. These are just guesses from my limited experience. It would take a pretty big error on the valve adjustment for the valve to hit the piston. I did a quick search on google and I think you have throttle body injection or TBI for short. This means that you don't have individual injectors for each cylinder.
I would check all the valves again (do more research on proper adjustment just to be sure you were doing it right the first time). I'm sure someone with more experience will chime in. |
#8
If you had that much fuel in the cylinder you may have hydraulic lock and bent a connecting rod.
Vince |
#11
Sorry to say it but I bet my last dollar you bent a rod. liquids does not compress very well. I did the same thing on my TPI motor. Bad injector and it fill the cyl with fuel and when I turned it over I heard a funny noise and the motor locked waited a minute and tried again but the damage was done. It started but the bottom of the piston was hitting the crank. Pulled it apart and had a bent rod.. I still have it hanging on the wall.
| Thread Tools | Search this Thread |
| Similar Threads for: "350 head gasket replacement...somethin went wrong" | ||||
| 350 Chev head gasket water holes too small? | rlmfire | Engine | 7 | 04-14-2007 08:11 PM |
| SBO 350, Head Gasket help, with photos | 360Camaro | Engine | 5 | 07-11-2005 08:29 PM |
| 3.8 Ford Head Gasket Questions | RCastle | Engine | 17 | 04-11-2005 10:14 AM |
| Head gasket replacement | adb2f | Engine | 4 | 12-19-2003 02:47 PM |
| To raise compressoin Head gasket?? | stereodud | Engine | 2 | 11-12-2002 04:52 PM |
