Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 heads
Thread: 350 heads
Old 12-06-2012, 03:54 PM
0trbo4myCHEVUICK 0trbo4myCHEVUICK is offline
Are 150$ heads going to get you rolling? When I was looking there was all sorts of used engines available for 300-500. Still in the car so you can check it out all you want before you buy it. plenty of vortec 350's. All around 150k but you will have that short block you saved to build on and learn on while you run the dog**** out of the used one. Hopefully by time you blow it up you will have the other motor ready. Then you have another 350 on the stand for rebuilding.
