350 heads on 400 eng. by mistake
I may have put 350 heads on 400 block, seem to run ok, what will steam hole in block do, thank you Ray
i've got a 400 ... ditto on the above... but
What all have you done to yours? I am planning a rebuild and would like to hear what other 400 owners have done. |
You need to pull the heads.
The steam holes let the water circulate around the clyinders. Without them air pockets form and they overheat. You can drill the steam holes yourself, but you have to pull the heads. I have a 434, .030 over, 4" stroke, splayed caps, forged crank, about .5" lift ( shoulda gone bigger) AFR 210 heads, but it pushed my '69 Vette into the 11.90's at 118mph all motor, crappy tune. 500 ft/lbs sure is fun on the street, as is 400 ft/lbs from <2400rpm to 6000rpm... |
If you remove the heads and lay a 400 gasket on them, you'll see 6 needed holes between the inboard cylinders. Mark and center punch where these line up. Using a sharp 1/8th or 3/16s bit; drill the exhaust side straight into the water jacket. On the valley or intake side drill at a 30 degree angle toward the exhaust side into the water jacket. Make sure your center punch is deep enough to keep the bit from skating off across the machined surface. Lightly dress the hole to make sure there's no raised edge or burr that would interfere with the gasket seal. Bogie |
pull the heads soon .. the block will warp slash crack if you run it to long like that...
as for 500 ft/lbs of torque..5.7 rod stock crank good roller hydrolic cam... haha yah and gas milage to boot in a 3/4 ton truck... |
Had the same problem on mine. I just got a .040 over 400 from a friend of mine, and the head gaskets were F##ked. It has a set of stock 350 heads on it, with no steam holes. I drilled them out, new gaskets, fired it up on the cart(74 Nova front clip) and she is solid.
| Distributor Tuning and Theory - Part 1 | Rick WI | Engine | 35 | 04-26-2011 12:38 AM |
| olds 350 #7 heads?? | Rough-Rider | Engine | 1 | 01-25-2007 04:19 PM |
| Piston preference for a 350 with 305 heads | Old School Baja | Engine | 0 | 01-07-2007 07:23 AM |
| 350 heads to a 400 SBC ??? | Rat Fink Jr. | Engine | 7 | 06-25-2005 11:45 AM |
| SBC 400 heads | wcpalmex | Engine | 2 | 06-15-2003 08:56 PM |
