350 heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2003, 12:38 PM
Post 350 heads
i have the set of "993" cast number heads for a 350 and i need to do a spring change and these heads have the stock diameter spring pocket size.. Does anyone know the size of the spring pocket? I am wanting to put a set of springs from comp cams in and they are a 1.440" diameter. i was just wondering if these springs would work in a stock spring pocket size.
Old 01-19-2003, 12:42 PM
NAIRB's Avatar
Post
The stock springs are only 1.25, and you'll have to have the spring pockets machined. Alot of shops use a shim in the original spring pocket, so they take the minimal amount of material to avoid hitting water jackets. You will need to machine it for the larger 1.44 spring.
