350 help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2010, 10:53 AM
350 help!
Hello out there fellow hotrodders. I need help! I am having trouble figuring out what bearings are the right for the crank and rods. I have a 3932442 crank, the old bearings say .010, however when I install the new bearings, the crank will not move, not even with a high peroformace starter hooked to it.I expect it to be tight but I don't think that's right. What am I doing wrong?
Old 05-30-2010, 12:14 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site, . Was everything marked before tear down so that all the rod and main caps go back where they came from. Is this a new build with machine work to the crank and block? are you sure you are putting the caps on the right direction also? are the bearing in the correct way do you have the thrust bearing in the right location ? Need more info on what exactly has been done to this engine to give proper help. JMO
Cole
Old 05-30-2010, 12:47 PM
350 help
Yes, I marked everything. I double hceked to make sure all of the bearings were sitting correctly. I am using a different block with the same casting. THe block that was damaged was worked .010, I put standard bearings in this morning and it works fine now. I am using the same connecting rods with new pistons so I am hoping to not have any other problems. I bought a kit from Summit Racing but most of the kit is incorrect, not their fault, I should have done more research before buying. I ended up with a .040 kit with pistons. Great service though. THanks, I will post when it is running, hopefully today!
Old 05-30-2010, 12:50 PM
eloc431962's Avatar
Wiki Edits: 37
So everything was checked at the machine shop? Needs to all be checked by a machine shop.
Cole
Old 05-30-2010, 04:15 PM
GMC boogie's Avatar
You are using STD bearings on a .010 under crank?
Old 05-30-2010, 04:32 PM
RattVette's Avatar
did you have the rods checked by the machine shop, I have seen rods that needed resizing do this
try starting from scratch, first install the main bearings and check for rotation then install the pistons and rods 1 by 1 checking rotation after each is installed, if its a bad rod this will identify it real quick
Old 05-30-2010, 05:09 PM
eloc431962's Avatar
Wiki Edits: 37
I just re-read the post and dang!!!!!!!!!!!! . To the OP you need to have all this checked at a machine shop. Or you are headed for some heartache. JMO
Cole
Old 05-30-2010, 06:10 PM
yea, I had everything checked out. IT is coming together nicely. RattVette, that is exactly what I did. one by one and it all checked out beautiflly. Thanks, I am taking a break and them on to the heads and into the truck. I'll keep you posted. I am excited to see it run
Old 05-30-2010, 06:35 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
This is very confusing. Maybe it's me.
Old 05-30-2010, 07:53 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Whats the bearing clearances? If you don't know run down to the local autoparts store and get plastigauge. Thats what I call it IDK if anyone else calls it something else. But they are little strips of plastic you put on a clean bearing and journal. You then torque the bolts and remove it and check to see how much its been sqeezed. This will tell you if the bearing clearances are right. Or get a mic and measure the journals. But like other people have said you might wanna take it to a machine shop to have someone look over it.
Old 05-30-2010, 09:42 PM
406 bug's Avatar
9.82 @ 139mph
Info for the future-- Never try turning a new motor with the starter- turn by hand first to check for the problem you found. (good thing in did not move)
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 06:22 AM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 12:44 AM
305 head on 350 savman1 Engine 4 10-15-2006 09:18 PM
348 or 350 delimma 62ImpalaSS Engine 12 05-17-2006 11:03 PM
