Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 high starter choice?
Old 01-31-2013, 08:43 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by cdminter59 View Post
Check out these starters. These are 3 hp and should turn your motor with ease. The only thing it doesn't say if it's for staggered bolt pattern. You will have to call to find out. I read about them on chevelle and corvette forums which said the Tilton was the best. CHEVY SMALL BLOCK/BIG BLOCK 3HP TILTON STYLE HIGH TORQUE GEAR REDUCTION RACING STARTER - BLACK
To use that starter there needs to be the straight across bolt holes in the block in good condition (not stripped or cracked casting where the starter mounts), as used w/the 153 T flywheel/flexplate. The starter will work on either size fly/flex using the straight across holes by using the different holes in the starter's nose.
