Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 high starter choice?
Old 02-01-2013, 09:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Jaykobo View Post
thanks.but want to ask about something
does the higher gear ratio make a better crancking?and does it need more ampers?
I was looking in summitracing and see most use 4.40 gear ratio
Proform High-Compression Racing Starters 67050 - SummitRacing.com
Proform High-Compression Racing Starters 67052 - SummitRacing.com
Tuff Stuff Gear Reduction Starters 6550B - SummitRacing.com
the last is 6:1 ratio
I will just take a round and see what can I found...thanks for the CFR starter...I will thinking about too
The 6:1 starter is using that ratio to overcome having a less powerful motor. It will work on either size flexplate. The Proform starters have to match the size of the flexplate, they're not a "one size fits both" deal, but they're more powerful.
Besides the battery voltage, the amp draw of the starter will depend on the armature windings/field strength and the amount of load the starter sees. It would be expected that a gear reduction starter wouldn't draw as much current as a non gear reduction starter all else being equal, due to the mechanical advantage it has.
