Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 high starter choice?
  #30 (permalink)
Old 02-04-2013, 06:29 AM
Greg T's Avatar
Greg T Greg T is offline
www.krusinklassics.net
Possibility that you don't have enough piston/bore clearance and the motor is nearly seizing. If that is the case you'll be destroying your pistons and bores. Maybe your ring end gaps are too tight, also?
