-   -   350 high starter choice? (http://www.hotrodders.com/forum/350-high-starter-choice-229015.html)
Jaykobo 01-31-2013 10:30 AM
Hi all:)
I have 350 TBI engine with CR 10.5 cadillac RWD 1990
when the engine warm it's hard to crank as and looks like a dead battery..I replace it with new higher AMPs....it's help little but the problem is still
the starter is OEM GM and :rolleyes:...I bought another OEM and do the same
I think it's need high torqe starter:D
so which brand offer good new good starter.....I found many and don't know which to buy:drunk:
my engine have full length headrs.....and want one fit
vinniekq2 01-31-2013 10:55 AM
check the cables and clamps. I use the full size high torque starter that Warren Johnson uses.In car for 10 years now,bought it from Lukovich
cdminter59 01-31-2013 11:20 AM
Do you know what flexplate you have? 153 tooth or 168 tooth. Does your starter have inline bolt holes or staggered.
Jaykobo 01-31-2013 11:32 AM
it's staggered bolts ....I already checked the cable......all are 100%
cdminter59 01-31-2013 11:36 AM
Is the engine a 5.7 Chevrolet engine or Cadillac engine.
Jaykobo 01-31-2013 11:37 AM
Forget to told you the fly wheel is 168 teeth
I see in summit many starters......tuff stuff ,summit,Proform High-Compression Racing Starters
and most are the same gear ratio...4.40:1 ......and find 6:1 tuff stuff
does 6:1 ratio is good or too much for starting?cos the price is very cheep which is 119$ only
I,m looking for one not more than 160$ us
I google about summit racing about starters and see many gets problem with it....not many recommend it
I,m looking for good quality and sure saving bucks
cdminter59 01-31-2013 11:47 AM
You still didn't answer the question is it a chevrolet motor or a Cadillac motor.
cdminter59 01-31-2013 12:12 PM
Good luck finding a high torque mini starter that is any good for $160.
Jaykobo 01-31-2013 12:13 PM
it's cadillac brogham 1990 RWD TBI .....it have the same engine and trans of chevy parts..nothing changed
cdminter59 01-31-2013 08:27 PM
Check out these starters. These are 3 hp and should turn your motor with ease. The only thing it doesn't say if it's for staggered bolt pattern. You will have to call to find out. I read about them on chevelle and corvette forums which said the Tilton was the best. CHEVY SMALL BLOCK/BIG BLOCK 3HP TILTON STYLE HIGH TORQUE GEAR REDUCTION RACING STARTER - BLACK
cobalt327 01-31-2013 09:43 PM
To use that starter there needs to be the straight across bolt holes in the block in good condition (not stripped or cracked casting where the starter mounts), as used w/the 153 T flywheel/flexplate. The starter will work on either size fly/flex using the straight across holes by using the different holes in the starter's nose.
Jaykobo 02-01-2013 02:12 AM
thanks.but want to ask about something
does the higher gear ratio make a better crancking?and does it need more ampers?
I was looking in summitracing and see most use 4.40 gear ratio
Proform High-Compression Racing Starters 67050 - SummitRacing.com
Proform High-Compression Racing Starters 67052 - SummitRacing.com
Tuff Stuff Gear Reduction Starters 6550B - SummitRacing.com
the last is 6:1 ratio
I will just take a round and see what can I found...thanks for the CFR starter...I will thinking about too
cobalt327 02-01-2013 10:28 PM
The 6:1 starter is using that ratio to overcome having a less powerful motor. It will work on either size flexplate. The Proform starters have to match the size of the flexplate, they're not a "one size fits both" deal, but they're more powerful.
Besides the battery voltage, the amp draw of the starter will depend on the armature windings/field strength and the amount of load the starter sees. It would be expected that a gear reduction starter wouldn't draw as much current as a non gear reduction starter all else being equal, due to the mechanical advantage it has.
Jaykobo 02-02-2013 06:41 AM
I just buy 2 starters
will see which better
http://www.cfrperformance.com/CHEVY_...-s2107-pbk.htm
and the summitracing Proform High-Compression Racing Starters 67052 "china copy of denso starters" as I find in google
http://www.summitracing.com/parts/pro-67052
thank you guys for your helps
gearheadslife 02-02-2013 08:21 AM
save you money, and just buy a remote starter selnoid kit.
it'll stop the heat soak hard starting..
jegs/summit/mad engineering. all sell them..
the kit is basicly a ford style selnoid and cables..
25-40 bucks..
