350 high starter choice?
Hi all
![]() I have 350 TBI engine with CR 10.5 cadillac RWD 1990 when the engine warm it's hard to crank as and looks like a dead battery..I replace it with new higher AMPs....it's help little but the problem is still the starter is OEM GM and ...I bought another OEM and do the sameI think it's need high torqe starter ![]() so which brand offer good new good starter.....I found many and don't know which to buy ![]() my engine have full length headrs.....and want one fit |
Do you know what flexplate you have? 153 tooth or 168 tooth. Does your starter have inline bolt holes or staggered.
it's staggered bolts ....I already checked the cable......all are 100%
Is the engine a 5.7 Chevrolet engine or Cadillac engine.
Forget to told you the fly wheel is 168 teeth
I see in summit many starters......tuff stuff ,summit,Proform High-Compression Racing Starters and most are the same gear ratio...4.40:1 ......and find 6:1 tuff stuff does 6:1 ratio is good or too much for starting?cos the price is very cheep which is 119$ only I,m looking for one not more than 160$ us I google about summit racing about starters and see many gets problem with it....not many recommend it I,m looking for good quality and sure saving bucks |
it's cadillac brogham 1990 RWD TBI .....it have the same engine and trans of chevy parts..nothing changed
Check out these starters. These are 3 hp and should turn your motor with ease. The only thing it doesn't say if it's for staggered bolt pattern. You will have to call to find out. I read about them on chevelle and corvette forums which said the Tilton was the best. CHEVY SMALL BLOCK/BIG BLOCK 3HP TILTON STYLE HIGH TORQUE GEAR REDUCTION RACING STARTER - BLACK
thanks.but want to ask about something
does the higher gear ratio make a better crancking?and does it need more ampers? I was looking in summitracing and see most use 4.40 gear ratio Proform High-Compression Racing Starters 67050 - SummitRacing.com Proform High-Compression Racing Starters 67052 - SummitRacing.com Tuff Stuff Gear Reduction Starters 6550B - SummitRacing.com the last is 6:1 ratio I will just take a round and see what can I found...thanks for the CFR starter...I will thinking about too |
Besides the battery voltage, the amp draw of the starter will depend on the armature windings/field strength and the amount of load the starter sees. It would be expected that a gear reduction starter wouldn't draw as much current as a non gear reduction starter all else being equal, due to the mechanical advantage it has. |
I just buy 2 starters
will see which better http://www.cfrperformance.com/CHEVY_...-s2107-pbk.htm and the summitracing Proform High-Compression Racing Starters 67052 "china copy of denso starters" as I find in google http://www.summitracing.com/parts/pro-67052 thank you guys for your helps Last edited by Jaykobo; 02-02-2013 at 05:48 AM. |
| high torque starter | tbrown8338 | Engine | 5 | 09-17-2012 07:14 AM |
| changed from oem starter to high tork mini starter , wires .? | don wills | Electrical | 2 | 09-04-2010 05:34 PM |
| High Torque mini starter | Craig legacy | Electrical | 5 | 09-18-2006 01:29 PM |
| High torque starter? | killerformula | Engine | 16 | 12-17-2003 06:20 PM |
| High-torque starter recommendations.. | 79454 | Engine | 10 | 10-25-2003 08:28 PM |
