350 with Holley 600 full-throttle miss
My T-bucket's 350 gets a miss at WOT which I suspect may be undersize main jets but have never rejetted so what are the symptoms? Everything else is perfect, performance is extremely strong in all ranges except wide open.
Holley 1850-4 (4160) with 64 mains, stock secondary plate, blue pump cam, white secondary spring. Secondaries kick in very smoothly by 2000 rpm and advance curve is very fast (yellow springs) and also all in by then.
I get excellent launches and tire-chirping shifts, but if I leave my foot on the floor it gets a light sputtering miss around 60-70 mph which clears up if I lift a little. 3.00 rear end means revs are pretty low and it does not miss at all until it hits 3rd.
Are 64 mains just too small? If so, what size should I use? Engine keeps loads of vacuum, so would 85 power valve help or keep the 65?
