hey i was wondering if someone could maybe dyno my engine and give me a ballpark figure.any guesses on 1/4 time? thanks
350 BLOCK, 2 BOLT MAINS
BLOCK CASTING NUMBER 3970010
eagle CRANK,
(OLIVER) 6" CONNECTING RODS - FORGED STEEL WITH (ARP) BOLTS
(WISECO)? PISTONS 6166A4 FORGED ALUMINUM FLAT TOPS - 2 VALVE NOTCHES - .927 PIN - SIDE HEIGHT 2.07" compression is 10.6-1
(MELLINGS) M55HV HIGH VOLUME OIL PUMP
BALANCER 3896966
CAMSHAFT- comps cam extreme energy(hyd. roller) .502/.510lift, 106 centerlines (not sure on duration i think its .234?)
DOUBLE ROLLER TIMING CHAIN & SPROCKET 3100 SRS
edelbrock performer rpm al. heads 2.02 intake 1.60exhst
edelbrock performer rpm air gap high rise intake, dual plane
holley 750 carb.
2800 stall.
1.5/8'' headers
the tranny is a 700r4 with stage 2 shift kit, rear end is ford 9'' with mini spool and 355 gears. its all in a 1987 gmc s-15, any guesses on 1/4 time? 15x10 slick, coil overs on the rear with ladder bars. weight is around 3300
eagle CRANK,
BALANCER 3896966
holley 750 carb.
2800 stall.
1.5/8'' headers
