350 hp...??? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 06-24-2008, 11:47 PM
With that setup there should be no reason for not having 300-325hp at the flywheel. Low end pull will be down because of the camshaft size, but instead of doing all this work to the heads, maybe a different camshaft like a XE262 would be best, good low/mid range camshaft. Aslong as the heads were free of cracks, they're a good low/mid range head, high volocity at lower rpm's, alot of vortec heads are 1.94's. A good set of AFR 180cc heads on that setup that you have, AFR dynos them around 430-440hp. Your safe at 300hp where you are
If you do not want to register, fill this field only and the name will be used as user name for your post.
1968 pontiac heads David Goetz Engine 10 12-21-2006 03:01 PM
White Smoke, I'm at a loss 58Chev Engine 31 09-25-2006 04:29 PM
how much HP in my 350? sseymour18 Engine 3 09-11-2006 04:50 PM
More HP for my 350? sscamaro_510 Engine 9 04-25-2005 08:22 AM
350 crate hp add ons blue85 Engine 15 11-19-2003 11:19 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
