350 hp help
i have a 350 with the casting number. 3970010 and was wondering how much hp the had.. it came out of a impla like a 73-75 i have done the heads are procomp, intake runner is 190cc and comb chamber is 64cc intake valve 2.02" and exhaust valve. 1.60" . the intake is a edelbrock performe intake off idle to 5500 rpm the cam is a edelb... rock performer rpm cam int/exh 234°/244° and the lift. 488"/.510" the pstons are speed pro with four eye brows, .125" dome... i was wondering if anyone would have idea how much hp and torque. i might end up with
350 help
If your engine is in top tune with no restrictions, I would guess somewhere at 390 hp and 338 lbs. of torque. One restriction is the intake. Off idle to 5500 and the camshaft rpm range is 1500-6500. The engine dies at 5500 rpm instead of making power til 6500. Get the performer RPM intake 1500-6500 RPMs
cdminter? curious as to why you estimate the horse power higher than the torque then claim the engine wont rev past 5500 rpm. How is that estimate even possible mathematically? do you know the rule of 5252?
so the other intake would make more hp? i was thinking bout getting it. so ima be making more than 350 hp?
350 hp help
350 hp build
| All times are GMT -6. The time now is 03:57 PM. |
