350 idles too fast - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2010, 09:21 PM
Aerotech's Avatar
350 idles too fast
I fired up my little roadster after a short Mississippi winter and though it was well set up when I parked it, it now idles too fast. Cable and linkage are loose, idle screw off the stop, choke off, everything for a slow idle and it won't settle down. I don't want to idle it down with ignition timing and kill the performance.
It's just a mild 350 with Comp 252, Holley 600, Weiand dual-plane, Delco HEI, and 1.72/1.50 Power Pack heads. No vacuum leaks. Why won't it idle down?
Old 03-11-2010, 09:35 PM
life is a temporary assignment
Look into the carb and make sure the bottom butterfly's aren't stuck open..
Old 03-11-2010, 10:07 PM
Aerotech's Avatar
Nope. Air cleaner off, everything cool. Haven't touched a thing since parking it.
Old 03-11-2010, 10:08 PM
also check the float level as if its a little high it will spill over and cause the same thing .
Old 03-11-2010, 10:25 PM
Aerotech's Avatar
Float level checks good. Set dry and confirmed wet.
Old 03-11-2010, 10:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Could be nothing more than a sticking mechanical advance. I'd suggest popping the distributor cap and checking it out.
A vacuum hose that's off or split could lean it enough to raise the idle.
Check the PCV valve to be sure it rattles.
Old 03-11-2010, 10:51 PM
Aerotech's Avatar
The flyweights don't come in at idle and the car has been driven enough to shake out any stickiness. It's the same setup that worked great when it was parked. I think it will eventually settle out but I am reluctant to mess with a good setup. It had a rotten vacuum cap which I replaced but there was no leak so it made no difference.
Old 03-11-2010, 11:07 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If they ever advanced when you first started it up this season (like if you blipped the throttle at start-up), then they didn't come back to rest fully- they'd still be advanced.
Easy enough to check.
Old 03-12-2010, 01:26 AM
sqzbox's Avatar
My pipes are my music
High rpm on idle circiut
Disconnect the vacuum advance hose on the distributor, plug the hose and see what it does.
Are you sure the hold down clamp on the dist. is tight?
If you have the idle screw off the stop and pull the throttle closed, does it make a difference?
It's hard for the engine to idle high on the idle circuit by itself and if there is no fuel dripping out of the booster more than likely, it's a timing issue.
After sitting for a period of time, it's a good idea to lubricate the throttle linkage and rods at the base of the carb. Also, the weights in the distributor.
Sooner or later, your going to have to take the cap off the dist. so do it now!
You don't have to change your setup to check it out.
Quit eliminating what you think is right and check to make sure it is.
I've found that the one thing I didn't look at was the very thing that was wrong and ended up kicking myself for it in the end.
Old 03-12-2010, 06:23 AM
Aerotech's Avatar
I've checked everything you mentioned except the advance. It's no big deal to pop the cap and give the flyweights a shot of lube. They've been through many cycles and never stuck before so I just assumed they were ok.
Old 03-12-2010, 09:52 AM
Frisco's Avatar
Glad To Be Here
Something else to look at.
After the choke fully opens, 'blip' the throttle to get the throttle linkage off the high idle shoulder of the throttle cam linkage. If it stays on that portion of the cam linkage the idle will be high and the throttle stop screws will be off the stop as well. The linkage could be 'dirty' and sticking as well.
Old 03-12-2010, 10:06 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I would agree- the easiest thing to look at, is if the curb idle screw is in contact with the carb linkage- w/o ANY gap whatsoever.
If the fast idle cam is holding the throttle open or if there's something binding in the choke flap or its linkage or counterweight, for instance- there will be a gap between the curb idle screw and the linkage.
Old 03-12-2010, 10:09 AM
sqzbox's Avatar
If the choke plate is fully open, the fast idle screw should be off the high point of the cam, manual or auto. tapping the throttle only opens the choke a little and in turn drops the fast idle cam down to the next lower step.
Old 03-12-2010, 04:23 PM
Aerotech's Avatar
Problem solved. Thanks guys! The car has no choke, so of course that's not it. I think somehow the throttle wasn't returning enough to get off the high idle step, even when moving the linkage by hand. Yesterday the idle screw was off the stop but today it was touching so I could back it off a turn. Good as new!
Old 03-13-2010, 12:43 AM
sqzbox's Avatar
So what your saying is the choke plate was removed but the fast idle cam linkage wasn't disabled? AAaaarrr! Bet you never do that again! Have fun!
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 07:22 AM
Bog/Black Smoke on Olds 350 at 3000 rpm JohnTN Engine 4 03-17-2009 12:39 PM
possible 350 block purchase - comments please idrva55 Engine 17 12-09-2007 10:29 PM
348 or 350 delimma 62ImpalaSS Engine 12 05-18-2006 12:03 AM
