350 info - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2012, 11:35 PM
350 info
i have a 350 with the casting number 3970010 and was wondering how much hp it had stock? and then im putting some procomp alum heads and a edelbrock performer rpm cam and its been bored .30 over with speed pro pistons, and a edelbrock intake, how much hp do you think ima be pushing with them add ons
Old 08-05-2012, 06:00 AM
350 info
Head specs, cam specs, piston specs, what Edelbrock intake???, carburetor size. No info to base assumption on!
Old 08-05-2012, 08:12 AM
68NovaSS's Avatar
Wiki Edits: 9
You may be able to pull numbers off the pad in front of the passenger side head to determine original hp. They made a kazillion 3970010's.
Old 08-05-2012, 09:25 AM
the heads are procomp, intake runner is 190cc and comb chamber is 64cc intake valve 2.02" and exhaust valve. 1.60" . the intake is a edelbrock performe intake off idle to 5500 rpm the cam is a edelbrock performer rpm cam int/exh 234°/244° and the lift. 488"/.510" the pistons are speed pro with four eye brows, .125" dome
goodwrench 350 info ryan v Engine 2 11-02-2011 04:51 PM
Vortec 350 info CJ_1080 Engine 11 12-31-2010 02:53 PM
Looking for some info on a 350 chevys camaro421sbc Engine 4 06-28-2007 01:54 PM
chevy 350 info joesnova2 Body - Exterior 2 07-19-2004 10:33 AM
350 rebuild info jlo829 Engine 3 10-22-2002 01:54 PM
