350 intake - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2002, 01:34 PM
New Member
Post 350 intake
I have a 1991 chevy s-10 blazer and i put a 5.7 350 back into it.it has the tbi unit and and the electronic dist. its the one with the ign contro module in side the cap well anyway i was wondering what all i need to do to change it over to a carb. i know i need intake,carb,and like an older style hei dist with vac advance on it. and the fuel pump i have to change right like to mech one or maybe inline fuel pump. i was just needed some info on this if all possible..thanks donnie
Old 12-31-2002, 06:58 PM
Chucks,57's Avatar
Cool
If you have the fuel pump in the gas tank Im' not shore of the psi but you can put a fule pump regulator for a bout $40.00 or take the pump out of the tank and put in a in line ,like a carter with a 7psi that would do you just fine, on the street you would wont to run no les then 4.5 psi at 72,gph. hope that helps.
Old 12-31-2002, 07:08 PM
dmorris1200's Avatar
doesn't play well with others
Post
GM TBI pumps generally run at much lower pressures than multi-port systems, usually around 13psi which is more than you want to use with a carb.
BUILT FORD TOUGH
Old 12-31-2002, 09:31 PM
New Member
Post
So if i just ran a preasure regulator with my reg pump where do i put it to be safe? does it have to be close to pump or carb or does it matter? now can i buy one that is set or can i buy one that i need to set? thanks guys..HAPPY NEW YEAR!!!
Old 01-01-2003, 02:54 AM
Chucks,57's Avatar
Cool
Put it some where you can get to easely,like the fire wall.buy it new it will come with step by step how to shet and at the fuel inlet on the carb mont a psi gage they are $10 to $20 bucks, so you can dile it in nothing to it,But if it was me I put a new fule pump on and get rid of that one in the tank,if its worth doing do it right! you dont wont a gas fire they suck! hope this helps,
Old 01-01-2003, 08:53 AM
New Member
Post
So if i put a new fuel pump in whats the easy way of doing it? Can I just take out the pump and extend it like with metal fuel line in the tank where it sets as the fuel pump did.Then run an inline or a mech one? Which would you all prefer.
Old 01-02-2003, 05:26 AM
Chucks,57's Avatar
Cool
On my sons S-10 we pulled the bed off to get to the tank thats' the easy way to do it to pull the tank off can be a rele pane in the *##!* the bed not hard to pull but you will need a frind or to'too help left it off then pull the pump out of the tank and take it to rad, shop and have them put a new tube on it.then find where the full line come out up front and re rout it to where you wont it to be.We put my sons fule pump on the frame in front of the tank, and the reg, on the fire wall.on the right side this was a 1988,S- 10.Hope this helps.
