Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 Leak
Thread: 350 Leak
Old 07-08-2005, 08:09 AM
bracketeer's Avatar
bracketeer bracketeer is offline
489 Lemans
Last journal entry: Street Legal
oil leak
First make sure the pan rails are flat. Overtightening will cause the bolt holes to buckle upwards causing a bad seal. Felpro and Mr Gasket both sell one piece rubber gaskets. They have grommets so you can't overtighten it. I have used both and found the Felpro to be better. Do not use RTV on it or it will leak. They work great. I never use cork anymore.
