Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 Leak
Thread: 350 Leak
Old 07-12-2005, 06:18 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Are you checking the shift shaft seal , the detent cable seal , tail housing to case, vacuum modulator?
The oil can travel around the edge of the case / tranny pan and drop off to the floor in a different loction than the actual leak
