Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 Leak
Thread: 350 Leak
Old 07-13-2005, 02:02 PM
Mertz's Avatar
Mertz Mertz is offline
I will be trying the talc trick tonight then I think I'm going to try a little right stuff around the dip stick shaft. I can't find the bolt that hold it in place so I'll try it the easy way for now.
I will try to clean up the other areas and see if I can see anything there as well.
I'm convinced now that it is not the pan. It takes awhile before I notice the leak after I clean everything off. I thought I had it with the last repair but by morning no luck.
