350 Leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2005, 07:57 AM
Mertz's Avatar
350 Leak
I have a turbo 350 in my 72 Chevy Pickup and it had a cork pan gasket when I bought it that leaked badly. I replace the filter and put in a new thin rubber gasket that came with the kit. This one leaked as bad. I asked the guy at NAPA why it would be leaking and he said it was because I use RTV sealant with it. I thought Bull! I went to my local speed shop and he recommended a product called Right Stuff. I comes in a can and sprays out a bead like a caulking gun. I used it and let the car sit until the material hardened. I started it up and it looked good until I drove it around for awhile. The pan is still leaking but not as bad but in more places.
In each case I torqued the bolts down to 12 ft pounds per the specs in the kit. I went back and tightened them to 15 with the rubber gasket with no help. I hand tightened the Right Stuff gasket a little more with no help. The pan is in good shape. I dimpled the bolt holes a little before using the Right Stuff and put sealer around them.
Any suggestions on how to get this thing to stop leaking? Fluid is getting all over my new exhaust and burning on. Any suggestions on how to get that cleaned off?
Thanks for the help
Old 07-08-2005, 08:09 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
oil leak
First make sure the pan rails are flat. Overtightening will cause the bolt holes to buckle upwards causing a bad seal. Felpro and Mr Gasket both sell one piece rubber gaskets. They have grommets so you can't overtighten it. I have used both and found the Felpro to be better. Do not use RTV on it or it will leak. They work great. I never use cork anymore.
Old 07-08-2005, 01:31 PM
Mertz's Avatar
Have you tried the fiber gaskets?
I checked the pan and it was flat. Tightened to 12 ftlbs
I am going to check the dip stick. The leak was mainly in that area when I started.
Old 07-08-2005, 04:27 PM
BigDawgsEatFirst's Avatar
400SBC4Life
alot of TH-350s
Leak from base of the dipstick
I have had three leak on me
and it does look like a pan leak
clean whole area of trans
and use some talc powder on area
then drive
your leak will show
Old 07-12-2005, 09:00 AM
Mertz's Avatar
I bought an aluminum pan so that I know it is straight and that I get a good mating surface. I roughed up the surfaces on both the trans and the pan and did not use any sealant. I torqued the bolt to 12 ft/lbs. I still have a leak. So I checked the dip stick tube and there does not appear to ba a leak out of it. It is pretty well encrusted with grease and dirt. I wiped some of the dirt and stuff off where it would show a leak.
I can the car and heated things up. I went back under and tighted the bolts to 15 ft/lbs. I figured the lock washer might have an effect on the torque readings. I checked the dip stick tube for leaks. I ran the car while under it and cleaned off all the old leak residue. I check the dip stick again. I ran it for awhile and did not see anything. I parted it with a piece of white cardboard under the pan. I checked it periodically during the evening and it looked like I had the problem solved. I checked it again this morning and found some trans fuild on the edge of the paper. I don't htink it is a porous body issue because the body seems to be dry and is pretty well packed with dirt. I don't think it is the modulator either.
I will get under it again this evening. I used a rubber gasket that came with the pan. As much as I don't want to change it again. That would teh 4th time. Should I use a different gasket material such as cork or fiber. It had a cork one on it when I bought it. I changed it because I thought that was the cause of teh leak.
Thanks
Mertz
Old 07-12-2005, 05:53 PM
Jmark's Avatar
After that many pan gaskets, I'd be looking elsewhere. Trans dipstick is a big one if its the old style "O"-ring. Front pump seal or front pump mounting 0-ring leak too.
Old 07-12-2005, 06:18 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Are you checking the shift shaft seal , the detent cable seal , tail housing to case, vacuum modulator?
The oil can travel around the edge of the case / tranny pan and drop off to the floor in a different loction than the actual leak
Old 07-13-2005, 02:02 PM
Mertz's Avatar
I will be trying the talc trick tonight then I think I'm going to try a little right stuff around the dip stick shaft. I can't find the bolt that hold it in place so I'll try it the easy way for now.
I will try to clean up the other areas and see if I can see anything there as well.
I'm convinced now that it is not the pan. It takes awhile before I notice the leak after I clean everything off. I thought I had it with the last repair but by morning no luck.
Old 07-14-2005, 02:23 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Did any of you guys happen to see at the GM dealerships how they have this stuff to check for antifreeze leaks? I think they make this same stuff for engine oil, gear lube, and for transmission fluid. It's just a pill bottle size liquid that will glow in the light of a blacklight. Follow the trail to wherever it starts. If they make it for transmission fluid anyhow. Just a thought anyway.
In a while, Chet.
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 06:22 AM
Bog/Black Smoke on Olds 350 at 3000 rpm JohnTN Engine 4 03-17-2009 11:39 AM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
possible 350 block purchase - comments please idrva55 Engine 17 12-09-2007 09:29 PM
rear seal leak on sbc 350 4onthefloor 2 Engine 9 03-23-2005 03:04 PM
