350 leaking oil
As some of you know my latest project is a 350 powered Jersey Speed Skiff.
Motor installed flywheel forward, 12 degree tilt to rear. we drive the prop off coupler attatched to the crank shaft. Motor has been slicked inside and Glyptalled to aid in oil flow back to the pan. Drain holes over cam been plugged with Moroso breather tubes. Pan Evac breather system. Here is the problem, I have an oil leak at the crankshaft sprocket, not bad but a little dribble. I have replaced the seal and checked the new sprocket hub....still leaks. I am thinking I have so much oil running down the inside of the timing cover, it leaks out the seal. Need more breather? more drainage? Any ideas fellas?
