350 machine shop questions - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-13-2011, 10:19 AM
1986c10's Avatar
and about the crank, the mains on the crank only have a few minor scratches so hopefully those could be polished maybe. we'll see. it looks like the bearings took most of the abuse over the crank.
  #17 (permalink)
Old 05-16-2011, 08:28 PM
1986c10's Avatar
one last question. must the same rod and bearing go back on the same crank journal? and must the same piston go back in the same bore after a rering and cylinder hone? Thanks again.
  #18 (permalink)
Old 05-16-2011, 09:55 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I would replace the parts in the same position they were in before hand. Only if the crank was turned and the bearings, pistons and rings were all new, except for keeping the rods in the correct orientation (big end bearing tangs and chamfers) and maintaining the correct rod side clearance, the rods w/new pistons and bearings can go back in the engine in any order. But used parts, I'd keep same to same.
  #19 (permalink)
Old 05-18-2011, 03:10 PM
1986c10's Avatar
Okay thanks for the info, i guess mine i can put where ever after hearing back from my builder. He said "I dont know who the hell rebuilt this but the cylinders are shaped like hour glasses and they "reground" the crank with sand paper". So i will have to have the "newly rebuilt" motor taken 60 over and honed, crank reground, block decked, cleaned, freeze plugs installed, cam bearings installed, heads milled all to a grand total of $610 in just machining on what was supposed to be a good motor... my butt was pretty sore after that phone call haha jk
Decking a 350 drock3969 Engine 30 04-11-2011 12:39 PM
zero decking block 1975yellowC3 Engine 53 10-02-2010 07:27 PM
Zero Decking a 322 Nailhead PsychoBandito Engine 4 10-30-2007 07:56 PM
Block Decking sb72elcamino350 Engine 3 02-26-2004 12:59 AM
decking your block 70 nova Engine 5 03-06-2003 03:04 PM
