350 marine engine help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2010, 06:20 AM
i'm looking to upgrade my v6 i have a 4 bolt block 14016379 vl145832 and 3890462 heads in the barn. might go with either a Weiand Action+Plus . or Edelbrock intake .carb unsure what to go with a holly or edelbrock 600 or 650. any suggestions ? wondering what hp i'm looking at. like to be at 260 or so
Old 08-03-2010, 08:42 AM
SSedan64's Avatar
Need more Info for a power output estimate.
You'll want low rpm torque for a boat engine with that low of a HP rating.
Edelbrock Performer intake, 650 Holley carb and a good Marine cam.
A set of Vortec heads from a 96-99 truck are worth 30-40 more HP than those old 462s.
Old 08-03-2010, 08:47 AM
SSedan64's Avatar
That Block # comes up as a 77-79 267 2-Bolt and a 350 2 or 4-Bolt. Make sure it has a 4" bore & 4-Bolt mains.
Old 08-03-2010, 09:23 AM
yes it's a 4 bolt main
Old 08-03-2010, 06:27 PM
vortech heads
You will need a vortech intake, Edelbrock RPM. Bigger is not better.
We used to drill the heads for early manifolds but there is not much material for threads.
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
SF oil???? n-gin Engine 6 07-09-2008 02:37 PM
Marine Engine Rotation 5.7L/260HP vtdrew Engine 21 04-27-2007 08:02 PM
maintenance of marine diesel engine exhaust pipes coll199 Engine 1 04-18-2007 09:47 AM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? wrmason3 Engine 2 09-14-2002 08:01 PM
