350 Mild Street Build Up Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2012, 03:38 PM
Hello all, I have a 4 bolt main 350 SBC I pulled from a Toy Landcruiser. It has a RV style came for torque and an Edelbrock performer series intake and carb with offroad seats/needles. When changing out the cam should I do anything else? Timing chain? new lifters? pushrods?
I am putting the 350 into an old volvo and would like to get some mild performance out of it, nothing crazy this will also be a back up vehicle. I have some Vortec heads to put on it, but I am looking for some input on what cam I should pick up and if I should do anything with the carb and or intake.
It will be a tight squeeze so I am thinking of ramhorn style exhaust manifold, I am not sure that hugger headers would give me more room?? 3" out the back?
Tranny, I ran by the junkyard and saw that they had a couple of V8 camaro's with automatic tranny's behind them. For $125 I will probably go that route...
Thanks in advance for the help!
Old 02-18-2012, 06:03 PM
BOBCRMAN@aol.com's Avatar
should I do anything else? Timing chain? new lifters? All these need to be new.. Pushrods can usually be re-used if the end balls are round and not scored or worn..
Old 02-18-2012, 06:36 PM
I would look into buying a complete late model 5.3 with trans. Complete from fan to tail housing and with all the accessories, including the ecu.
You will end up spending less money and power and mpg will be better.
1200 dollars you should be able to get a complete later model driveline
Old 02-18-2012, 06:38 PM
That is a possibility, would the wiring be a pain in the ***?
Old 02-18-2012, 07:13 PM
Ive steered away from late model engines because of the wiring and ecu. May not be a pia to some but it would be to me. Plus why spend more $ if you already have an engine.
262 Mild build.. Need Help!! Matt262Blaze Engine 7 03-15-2011 07:37 AM
Mild 350 SBC Build WesTXmc Engine 4 05-20-2010 03:20 AM
Help on mild 350 build.. Meangreen Engine 14 08-26-2009 07:16 AM
Mild 350 build... need help 350cruiser Engine 32 04-07-2009 09:29 AM
mild sbc build help, cam help callmejavier Engine 20 04-16-2008 06:56 PM
