Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 misfire/backfire
Old 11-07-2012, 01:35 PM
Stormtrooper Stormtrooper is offline
Alright so i have a 350 engine, vortec heads, edelbrock intake, comp roller tip rockers, 650 edelbrock thunder series carb. Intial timing at 11 degrees.
Right now it idles terribly, backfires out the back some and wants to die if i dont let it warm up enough for driving. Also misfires at any engine speed(dash shaking) and im way down on power.
I replaced the cap, rotor, coil, control module and the plugs when the module went out a few weeks ago.
i adjusted the valves messed with the carb adjustments when misfire started and still nothing. also ran some seafoam through the tank and carb still nothing. iv been hella busy with work though so i dont know when exactly the problem started. The plugs were black so im thinking i might lean it out with a rod change but it has always run rich. even before the problem started just havent got around to getting new rods or springs for it.
any help is appreciated as this is very annoying
