Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 misfire/backfire
Old 11-09-2012, 07:53 AM
cdminter59 cdminter59 is offline
Here is an article on hotrodding a HEI distributor. http://www.crankshaftcoalition.com/w...EI_distributor. It also has tests you can run to check the pickup, coil, etc. You can also check the resistance in your sparkplug wires with an OHM meter.
